Faced with the old problem of how to drain condensate from a propane bottle air reciever I have come up with a solution. I removed the valve and replaced it with a 3/4 BSP nipple, on to this I fitted a 4 way 3/4 BSP cross fitting. Into the top of the cross fitting I put a 3/4 - 3/8 reducer and into that a 3/8 BSP to 1/4 compression fitting. Before fitting the compression fitting I drilled out the inside of it so that a 1/4 copper pipe would pass right through.
I passed the copper tube right through the compression fitting, through the cross piece and down to rest on the bottom of the cylinder, I cut small notches in the end of the tube first so there was no chance of it getting blocked when in contact with the base of the cylinder. The other end of the 1/4 copper tube bends back down the outside of the cylinder and terminates with a valve. Opening the valve with the cylinder under pressure forces any moisture in the bottom of the tank out of the drain valve.
The left and righthand spouts of the cross fitting serve as air in from compressor and air out to workshop. Sounds more complicated than it actually was. Photos help explain.
