Hopefuldave
Intergalactic pot-mender
- The Shed of Danger, surrey, England
Use glycol based antifreeze, or ideally, the proper TIG coolant which is low-conductivity.
A WP18 sized torch needs next to no flow - I had an 8m wp18 on my old 250a AC/DC machine and used a weedy pond pump with a tiny pressure head - like 1.5m or so - and it never, ever, got hot.
A Wp20 sized torch needs a GOOD pump with 1.5 lpm + flow and a few bar pressure.
For info, 10m head is only 1 bar / 14 psi, my WP18 needs a lot more than that...
One of these works, but Jeez, are they noisy!
https://www.ebay.co.uk/itm/72W-RV-C...510352?hash=item5939e6b550:g:eywAAOSwfrldrXgk
Helps to mount them with the silicone rings from the "personal supplies" top shelf in the Pahnd Shop
and penny washers!May be the flow sensor on the return hose restricting, but the gauge on the flow side reads about 60 psi to get 2 (or slightly more) litres/min flow - or my torch may be scaled up from previous abuse with tapwater...
The pulsing from the diaphragm pumps (which you feel in the torch and hoses) can be taken out with a fizzy pop bottle upside down with a hose barb in the cap, leave air in it for a "spring" (tested to 150 psi on 2L bottles, the diddy 6-for-a-quid Poopsie Coola bottles in the Pahnd Shop should take more...)
Dave H. (the other one)
