123hotchef
- Kent
I'll keep looking I do like the option of the dual one with air supply and a hand pump
No point in the ones that can be used to extract and refill. They are almost impossible to clean so,as soon as you have filled them with old dirty oil any remaining in the pump will contaminate your nice clean oil.
What legislation covers pumping oil out of a car engine?All dealers have them to comply with current legislation but not all use them and for good reason, many vehicles were never designed to use them and they cannot suck all the oil out.
Vauxhall are a prime example and some models are suited to pumps as their sump bung is not at the bottom of the sump and it leaves about 1 litre of old oil in the sump and the pump gets most of this.
Other models have their sump bung at the bottom of the sump and draining it out through the bung gets all the oil out.
Know your make but not the model so a little assumption here, some of the models of your marque have a little perforated tube in the old dipstick hole and this leads the extraction pipe into a small sump within the sump and being at a lower point means it gets all the oil as it drains into the extraction sump.
Certain Vauxhall model leaves 1 litre in the sump and holds 4.2 litres and that isn't a ood dilution rate.
It's not the pumping out. It's the draining through the sump plug.What legislation covers pumping oil out of a car engine?
why incase they strip the plug threads or get oil in their eye!It's not the pumping out. It's the draining through the sump plug.
It's in case they get a splash of used oil on them and get cancer 40 year's later.
The only thing I can find that is regulated is 'end of life' and that says either gravity or pump.What legislation covers pumping oil out of a car engine?
Me too. Most days for 30 yearsThat me stuffed then, splash? I have been covered in it from head to foot before now
Bob
Which model range are you referring to?
