JonnyAlpha
Hi;
I am about to replace the Flitch Panels and Scuttle Ends on my Mini and have been advised that (as a conventional Angle Grinder is to large to get into all the areas required to be cut and welded) an Air Die Grinder would be required.
I am on a tight budget (as usual) but any recommendations would be appreciated. A good set of Burrs would also probably do the trick?
Also can a Die Grinder take a cutting / grinding disc or is this a different tool altogether?
Thanks
Thanks
