forget builder merchant for brick cleaning acid ebay is your friend stronger and cheeper acid
I use citric acid a lot, if you mix it up with hot water it works in about half an hour on hot rolled strip. I keep meaning to buy one of those heater
elements used by home brewers. for long bars and strips I use a length of drainpipe with a bung up the end of it.it is also safe to dispose of down the drain as it is a food product.
Big bags on eBay is where I get my supplies. Aquarium heaters are a good source of heat as well as the brewing specific ones can be a bit more expensive even though they're the same thing.What's a good source for citric acid?
I would not have any of the serious acids around due to pets and children etc but vinegar and similar are easier to manage.
