angellonewolf
- bristol england
my inpact blupoint says 6.2cmf
The tool will only use what cfm it needs, cheap tools use more through bad designhow can i tell if im putting more cmf in it than is needed ?
To get full power from it it will need 6.2 cfm air flow and a at least the same free air delivery from the pump if it needed to keep up with usagemy inpact blupoint says 6.2cmf
Because that's the maximum it will use, and people usually match tools to the air supply they have especially for heavy use for home use where you won't hammer them you should be ok, if you use more then the pump supplies you'll just have to wait for the pressure to build then carry onwhy does it say max then (not trying to be funny or rude) am i worry about nothing and just use it as is with no reg ?
the only other thing i use is for compressed air to clean stuff out not done any spraying in years
As snoops say you cannot force more cfm through, at 10 bar, but you could if, you raised the pressure to say 20 bar air pressure but that would damage the gun.The tool will only use what cfm it needs, cheap tools use more through bad design
