JonnyAlpha
Hi;
Having just removed the rear subframe on my Mini I've spotted a couple of dodgy areas that I need a bit of advice on.
There is some rust on the top plate of the RH main strut, these plates are replaceable so I'll either replace the plate or facilitate a repair to the existing one.
But there is a slightly more challenging rusted area inside the RH main strut in the bottom corner behind the Cone housing.
Another photo of the same area at a different angle.
Would this area be repairable by cutting out the patch and but welding it in place??
I'll manually clean up the whole sub frame to confirm the actual extent before starting to spend any time on it. I am on a very tight budget and a new Subframe is out of the question, old ones on E Bay start at around £50 but still need work?
Most of the Subframe looks sound.
