Yes pdg that is obviously correctDo you mean using a press to install?
I was always taught to never apply pressure through the bearing during fitting - so if it goes on a shaft you only press on the inner, in a recess you only press on the outer...
Steve pleasedecided im goning to give this new one an extra heave on the bar ...obviously doing something wrong and thats the only step i can see that go wrong ?
Question is, what do you do when a press is a tight fit in a housing and on a shaft at the same time...?
You use a flat faced tool that bears against both the inner and outer races. Relieved in the centre to clear the shaft if necessary.
Very unusual to have to do that in the case of wheel bearings though, more replacing bearings in a machine that has fixed shafts.Question is, what do you do when a press is a tight fit in a housing and on a shaft at the same time...?
he would whinge even more if you damaged a new bearing or the machine itself though !!Yes, but even if there was a lathe at work the boss would whinge about the time taken to make the tool, given how much he whines about the time taken to do the job in the first place!
Hum and 'WE' hope he isnt a member of a welding forum with a pseudonym either----- I believe.My boss is not known for having any grey matter whatsoever,
not forgetting this is in a public domain !!
best idea they are not that dear anyway.so ive ordered up a new drum
the hole in the housing /drum will quite easily deform a bearing, the drum being much larger dia will try keep its shape even if that shape is now oval, so the round outer race of the bearing will now become oval the same as the disc, the outer race then will have highs and lows ie more load on bearing where it is forced inward.i cant see a slightly iffy opening deforming a bearing but then what do i know lol
No unless they have been fitted cocked overwould there be a limit to how many bearings can be swapped into a drum before things go wrong , its had 3 fitted in it now
