[/quote]you would need a neutral though one of the problems of doing that is you can overload the neutral in the run from the CU to socket l[/QUOTE]
I have tapped the neutral as well as the active and also the earth, overloading the wires is not something that I worry about as the wires from the house pole are 25mm to the main circuit box, the wires from the house circuit box to the shed's sub-board are (about 9m apart) 16mm copper, and from the sheds sub-board to each 3 phase wall socket is 10mm copper and lastly from the 3 phase socket to the 15A 240V GPO's are 6mm cables. There is also another independent and separate 240V sub-board in the shed running 2.5mm copper to other power points. That 240V sub-board was installed first before I put in the 3 phase to the house and the shed, and is 10mm to the main house circuit box. So not much chance of anything overloading the circuits, even my 3 phase MIG welder which can draw 27KVA runs quite happily on a 6mm 18m extension lead.
