whm_fab
Motorsport engineering
- in the shop
Hi Gents,
So im getting close to running compressed air around my workshop for everything from air tools like impact gun, die grinders, air saw etc to plasma cutter.
After trying to do as much research as i can (ive over-researched) and now im bamboozled with what setup i need in certain parts.
Few things i do know that ive settled on:
- - The main line around the workshop which will be about 40/50m will be 1/2" PEX (no not PVC before anyone has a heart attack)
- - The drops will also be 1/2" PEX
- - The fittings will all be PCL XF
What im confused about and what i need help with:
I'm totally confused about the threaded fittings and internal bore to suit certain tools, with BSP/NPT 1/4" , 1/2" etc etc.
I suppose my main query is the most fittings i see are actually 1/4" BSP. In theory does this make the flow advantage of running 1/2" pipe around the shop a waste of time? will 1/4" BSP fittings run say a die grinder or DA ? or do i need all 1/2" fittings??
Same with the regulator/drier at the compressor - most of them i see are actually 1/4" BSP fittings - again do i need to find a 1/2" reg to take advantage of my 1/2" supply piping?
Or, am i over thinking it and will 1/4" BSP run everything i require absoutly fine?
Thanks!!!
Thanks!!!
