Most nozzles used are ceramicCant see the point really. Ceramic nozzles arn't very dear
but carbide is better so don't botherMost nozzles used are ceramic
How long does it take to modify a spark plug?I saw it on the internet, has anyone done it? How good does it work?
And very expensive :Pbut carbide is better so don't bother
about 7 quid or £7 .00And very expensive :P
Really??? I saw one that costed like 30 dollarsabout 7 quid or £7 .00
Could you send me a link where I could buy it?large ones are the 3mm ones are roughly 7 quid .my 6mm one supposed to cost £ 60 .00
I was talking about the 3mm one :PI cant it fell of the back of a wagon u would need a minimum of 80cfm comp to run a 6mm jet
Ahahah yeah I was searching right now and also found those. I will probably use the spark plugs in the start and when I get more money I will try to buy the carbide one. The carbide one looks straight how does it stay "stuck" to ball valve? Shouldn't it be conical?oops there 17 quid not 7 http://www.ebay.co.uk/itm/TUNGSTEN-...hash=item33cc133acc:m:mgoP9LooLdOOm8BU3DC_XvQ
cut the ball valve off blast hose and fit direct in to hose using a jubilee clip and work pot from ball valve on air supplyAhahah yeah I was searching right now and also found those. I will probably use the spark plugs in the start and when I get more money I will try to buy the carbide one. The carbide one looks straight how does it stay "stuck" to ball valve? Shouldn't it be conical?
