no, the nato ring wont take to it too well, i mentioned in that post and as someone else said, nato hitch for a nato ring, and plenty of grease too.^^ If you get one of those make sure it fits the NATO ring properly. I'll post a picture with measurements later.
Even a proper NATO hitch WILL jam up if both the coupling and eye are set to revolve...
Did say that
not a coupler ive had much to do with other than hitch an odd one up now and again but enlighten me a bit to the problem with both units swiveling, what can happen?Even a proper NATO hitch WILL jam up if both the coupling and eye are set to revolve, there should be a warning on the trailer, often painted over.
Wasn't thinking that. Been there done that at Rushmore arena aldershotYou did and I wasn't trying to upstage you, sorry if you thought I was, but some folk who might find this thread may not be able to see exactly why there could be a problem, so I thought I'd explain a bit more from my experience.
Yepi get it now, common sense really, only one of them ever needs to turn anyways.
Interesting. I know I need to raise the height of the hitch because of the height of a sankey trailer. I already have this.
http://www.rimmerbros.co.uk/Item--i-STC50319
Was thinking of using a 10/15mm plate to bolt to the top two rows on the tow bracket which extends up to level with the bumper to raise the height of the hitch. A NATO hitch usually fastens to the rear cross member on a defender but a disco doesnt have that feature.
It's not a standard trailerYou should not use a dropper type plate to raise the hitch height on a standard tow bar.
