Premiershipman
- Isle of Man
This was the latest project, completed only a few weeks ago after coming across the rocket stove idea on other forums.
If you haven;t looked at these they are esentially billed as ultra efficient stoves that use up the majority of heat energy when burning wood at high temps, and only exhaust steam and warm air.
So after a bit of research I decided to cobbled one together from propane tanks.
I already had one 19kg that I had planned to make a patio heater from so I gave a mate of mine a shout who supplied another 19kg and a 47kg one.
The idea was to weld 4" box section into the middle of the the two 19kg cylinders (the 19kg cylinders welded one on top of each other) and then fit that inside the 47kg.
Excuse the crude ascii type drawing but it does help to show the arrangement :
/ \ The section with all the X in is the box section feed pipe, wood is fed into the
| |oo|X|oo| | front section of the feed pipe and as the unit heats up it creates the
| |oo|X|oo| | draw which further helps burn the wood and create the 'rocket' sound that it
| |oo|X|oo| | gets its name from.
| |oo|X|oo| | As the flames and heat rise up the box section inside they hit the top plate of
| |oo|X|oo| | the stove and then the heat is deflected round the inside of the 47kg
| |oo|X|oo| | The oo is insulation around the box section inside the 2 19kg cylinders,
| |oo|X|oo| | / X / the top plate is an offcut of the 12mm plate from the welding bench.
| |oo|X|oo|_|_/ X /__ The exhaust gases come out vie the 4" tube at the back and when it
__ | |oo|X X X X X X X X gets installed properly in the garage it will feed into some galvanized
__ |ooo ooo| | ducting that I have.
|____________|
So far its only been tested out in the open, but it has got to about 400C on a small bucket of sticks so it works pretty well !!
Pics to follow !!
Shady
|____________|
Pics to follow !!
Shady
