Brad93
- Essex, United Kingdom
When talking of different stainless steel grades or any materials really it is important to know why they corrode.
There are 8 different forms of corrosion or should I say forms of attack.
There is basically the following:
Most austentitic stainless steel is obviously highly resistance to the elements, with certain grades being better suited to marine use.
As has already been explained the chromium in the stainless steel creates a tough passive oxide layer that prevents the underlying layers from being exposed to oxygen or nitrogen.
However not all stainless alloys are resistant to the same environments, for example elevated temperatures, presence of acids or organic material etc can break down the passive layer.
When you get embedded iron particles on the surface of stainless steel, you get galvanic and crevice corrosion occurring. That little iron particle basically creates a localised potential forming an anode and cathode.
Similar occurs with chlorine, sulphur, vanadium and other elements on what would normally be very corrosion resistant materials.
I could talk about this all day but the best resource there probably is around is a book by Fontana & Green called Corrosion engineering.
I forget how many revisions there are, it’s been reprinted and updated many times. The guy was about in the 40s!
Bout £20-40 second hand online.
Once you’ve got the book look up a guy on YouTube his name is Thomas W Eagar, American Professor at MIT. His video series on corrosion is quite interesting.
- Uniform
- Galvanic
- Crevice (Under Deposit Corrosion)
- Pitting
- Intergranular
- Erosion
- Stress corrosion
- Selective Leaching
