Adamfromscotland
New Member
- Ayr Scotland
Hi
I have a SIP Air compressor and a 20 Gallon sand blaster bought from different sellers, the specs are below
The compressor looks well and seems to run very well and the dials go up
But the sand blaster which is empty of sand and all the valves are open
The problem is on the sand blaster I hear all the air coming out of the dial valve at the bottom of it, its hissing out and the tank doesn’t seem to fill? And the sand blaster nozzle doesn’t have any air coming out of it?
Does anyone have any idea what im doing wrong? I contacted the sand blaster guy he said: I need at least 14CFM and 200l Compressor! But I emailed someone else selling the same 20 gallon model he said: my existing compressor will be fine!
What is up any help is appreciated!
As I cant afford to buy a new 230v 14CFM 200L air compressor and not many of this spec on ebay used!
SIP T3 06636 3HBP 150 LITRES Free Air Delivery CFM: 7.8 (221 L/Min)
AND SAND BLASTER IS:
Tank Volume: 20 Gallon
Air Consumption: 6-25Cfm
Working Pressure: 60-125Psi
Hose Length: 2.5m
Dimensions: 880*460*420mm
Nett/Gross Weight: 21/23kgs
Hose Length: 2.5m
