Wondering if anyone on here can help me with a problem I've got with my Snap On Pro 160 welder.
Basically what's happening is the wire is sticking to the tip. I don't think it's a wire feed issue, I've fitted a euro torch conversion, changed the liner and so on, the wire runs free when not welding and pulls through ok, but when I weld either just as I start or after it's been welding a bit it will stick in the tip, normally with 5mm or so sticking out. If I then flex it, it will ping free and the wire shoots out a bit. If I then feed the wire out, the wire feels rough as if it has spatter stuck to the wire but it's well back inside the tip. If it's been welding ok and I stop and wind out more wire it feels smooth as you would expect. The wire is good and clean and I have tried lots of wire. It also appears worse on the higher amperage settings.
I cannot understand how this can be happening, so any help or insights would be greatly appreciated.
