Shed engineering, got to love it...Don't ask. This is completely normal and 100% not a scary lash up, honest. Machinists look away now. Health and Safety people should delete the entire bookmark.
But at least they're back flat now:
So these discs warped when they were hot zinc plated, and the plan was originally to heat cycle them gently to get the stress out of them, then take them off the car and grind them flat before the car got used in anger.
That obviously never happened and because they were getting hot spots they got worse and worse lately - the things had more bow than a pringle in them.
Ground them back flat in a seriously Heath Robinson manner for now, just to get the brakes back, as it's been knocking the brake pads back and needing the pedal double pumping at higher speeds - they were half a mm out of true (discs should generally be under 0.05mm)
Obviously not good, so this is a temporary fix for now, and then we'll get some more cut either out of cast iron plate if we can manage it (which I originally wanted but our parts are so small you have to wait until somewhere has some spare offcuts basically) - or probably have them done out of 10mm thick plate next time, stress relieve them and then machine them back true to 8mm thick - I've already got a jig for it as we made one to do the discs originally before we got carried away and forgot![]()
AwesomeWhen it's in the shed....sometimes.
