You'd have to forge it flat , as most will have some curve in them and the shorter one or two will usually have a centre bolt hole in them to locate them on the axle pad .Lorry leaf spring
Forklift tines are supposedly good for that purpose.
If you're anywhere near norfolk I've got scrap forklift tines you can have for free.So, they don't have to be super thick, since I am thinking of welding them onto thick blocks of mild steel. They just have to be thick enough to be the hardened work surface for the anvil.
I don't mind scrap since I can clean it up. Like I say, it's for anvils not something that must be brand new and conform to any regulations etc. More just does the job and looks the part.
Any ideas guys? Thanks.
I'm assuming if he is making anvils he has a forgeYou'd have to forge it flat , as most will have some curve in them and the shorter one or two will usually have a centre bolt hole in them to locate them on the axle pad .
No, I don't have one. Just a horizontal bandsaw and angle grinder at the moment.I'm assuming if he is making anvils he has a forge
I have to ask, why do you need an anvil then?No, I don't have one. Just a horizontal bandsaw and angle grinder at the moment.
I don't. I'll be making them to sell.I have to ask, why do you need an anvil then?
So how do you know if they are any good ?I don't. I'll be making them to sell.
They're pieces of metal which are going to be used to put hot metal on and hit with a hammer. It's not exactly precision engineering. I won't ever claim it to be, and most people are intelligent enough to know that.So how do you know if they are any good ?
About 15-20kg at the moment.What size and wieght do you imagine your anvil products?
Woah !They're pieces of metal which are going to be used to put hot metal on and hit with a hammer. It's not exactly precision engineering. I won't ever claim it to be, and most people are intelligent enough to know that.
Get one from an old scaffolder's lorry, it'll have been over loaded that often it'll be bent flat.You'd have to forge it flat , as most will have some curve in them and the shorter one or two will usually have a centre bolt hole in them to locate them on the axle pad .
The rear leaf spring set off a Mighty Antar MK1 ballast body towing out fit would have been ideal about 16 leaves ,5 inches or more wide , stacking up to around 18 inches thick .... A hellofa job to replace a set even in the workshop with a handy over head crane .Get one from an old scaffolder's lorry, it'll have been over loaded that often it'll be bent flat.
I've never understood why people especially in the USA wrap chain s round their anvils to deaden the noise & response .
It means there is no resonance so the hammer blow is a dead weight smash rather than a number of micro vibrations which kind of shot pene the steel or iron being forged & makes it stronger IMO.
