neilgrahamirwin@hotmail.c
1 coat would be good if i can get away with it
What make of paint is it, and what type??? Any labels on the tin??
Personally, I would not heat the paint- I would decant about 200ml into a plastic (Clean and grease free!) jug or paint mixing cup and dilute with about the same volume of cellulose thinners.
I found that Chassis black, when applied neat takes ages to dry but when sprayed on diluted with thinners dries to a tack in about 10 mins, enabling another coat to be applied.
Experiment on some scrap pieces!
just back on the heating the paint issue-when you say put in a saucepan of boiling water-i assume this is after i have taken it off the heat source? If o how long shall i leave the paint can in the water to get it nicely heated-are we trying to get the paint a bit warm or hot? Once i have painted them up i then leave them for normally 48hours, so i would imagine they would be dry by then?
I guess it's horses for courses, having been a pro truck sprayer many moons ago, we always did hot spray. You get the best finish with one coat. Yes it may take a little longer to dry, but you'll get a good heavy finish which is ideal for a chassis, and you don't have to re-coat it.
If you do go the thinners route, I wouldn't use cellulose thinners, use a proper synthetic thinner.
Yes Neil, you can be a bit limited on how much you can heat up, but a litre of paint will go a long way. to put it in to real terms, I could hot spray a panel 10' x 6 with a litre of paint.
Either way Neil, spray how you feel comfortable, it's all very well me saying my bit, but you're doing it, not me, so as CJ just said, do some test pieces, and see what you come up with.
Thanks Langy.....I was beginning to think my advice was from the dark ages!!!
Whatever you do neil, don't put too much synthetic thinners in it, it won't take a lot to throw it into a very runny mess!!
We might both be from the dark age mate
Lol, yeah maybe you're right...happy days they were too!!!!!!!!!!!
I've just been having a little nosey at your website, couldn't help but notice that chevy pickup (or is it GMC badged?!) I'm at the tail end of doing a 1950 3100 (original spec) for a friend, so as you can imagine, if I see a pickup, I'm drawn to it!!!!!!!! I'm thinking that one must be around 55-57?????
So tell me is it yours???
Ah hell, I was way out then....well, apart from the year(ish)!!!!!!!!!
That's a beauty mate, very very nice indeed......and then you go and sell it!!!!!!!!!
