robinsoncrusoe55
New Member
Good evening everybody, I've got a one off stainless steel welding job to do, and was after some much needed advice.
I have got to weld a stainless steel support unit, the base plate, is about 3.5mm thick,
and needs a 40 mm square section support column, welders to the base plate.
I have already purchased a pack of 10 2.5mm, type 316 L, rods. The arc welder I've got,
is a Clarke, unit, with about 100 amps output.
The unit will not have to support more than 2lbs, in weight.
I have done a very limited amount of mild steel arc welding.
Where to start.........
