My Movano had a jump point in the engine bay, not noticed one on my 05 Master, yetSeveral makes recommend switching sidelights on to avoid any damage.
Vauxhall movano/Renault master if you muck up the connection when getting ready to jump start then you have to take the passenger footwell apart to access the battery (jump points are under the bonnet) take the terminals of the battery and hold them together. It resets something.
I have no idea the reasons why it went have 5 Renault masters and have had to do it quite a few times.
My Transit has as well, I assume this is because to access the battery you need to remove the seatMy Movano had a jump point in the engine bay, not noticed one on my 05 Master, yet
You would be correct, got stranded when my iPace battery wasn't charging, RAC patrol pumped some juice into the 12V battery so I could drive it homeAn advantage with EVs...if everything is working correctly they top up the 12v battery from the main traction battery I believe.
....if everything is not working correctly I've heard they too may need a jump start!
I find these interesting. I have had several instances where using the jump points I have been unable to start a dead vehicle. Linking straight to the battery and it has started as expected. I dont know why this is. I would have thought the jump points were merely an alternative connection point and shouldnt make a huge difference to how the connection works?My Movano had a jump point in the engine bay, not noticed one on my 05 Master, yet
Not quite the same, but a common failure of my model. Hyundai 12V batteries are junk. They replace if they fail before two years, but they don’t often last much more than 2 years. I carry my lidl jumper in the glove drawer so I’m ready if/when it decides to give up.You would be correct, got stranded when my iPace battery wasn't charging, RAC patrol pumped some juice into the 12V battery so I could drive it home
If that's the case, then you have a problem - no vehicle 'modern' or otherwise, should draw >50mA quiescent current, usually much lower, around 30mA. I'd suggest you have the cause investigated whilst it's still in warranty, the good thing is that there should be comprehensive battery monitoring stats available to confirm the concern and point to the cause - which may well be the starter battery itself.
That's wrong surely!
My Surf sits unused for quite long periods of time with fairly old batteries and only needs a jump start very rarely.
I've also heard about this being done, gel battery from a mazda mx5 works well apparently.There was a used car lot opposite the shooting club and I've seen the owner jump starting cars by inverting a good battery and jamming it on the terminals of the dead one no jump leads required.
I wish I was that laid backIt's a known issue and not something the dealer can address. I'm ambivalent about it now - it doesn't cause me any problems day to day...
Just to point out that any vehicle from the 2000s should comply with various standards. One of which is ISO16750-2 that defines load dumps etc., so any electronic systems should be protected against jump starting, jump packs etc.
This is an interesting read at least for the graphs which show what kind of transients they should be protected against.
If stuff fails then it's either a very very extreme case or it's not been tested thoroughly enough by the manufacturer.
When we build automotive electronics it's pretty common to protect against over voltage, under voltage, surges, transients, spike suppression, reverse polarity and load dumps.
A class action lawsuit has been filed against TRW and its parent company (ZF), Honda, and Toyoto for equipping vehicles with allegedly defective airbag control units. The complaint says that TRW’s control units don’t have sufficient protection against electrical overstress, which can lead the units to fail during a crash.
There are a number of companies that repair Fiat airbag ECUs Crashdata repaired mine , 48 hrs from posting it off to refitting it. Don’t know if you have tried getting yours repaired?Should being the key word...
Probably not the ones that Fiat use for the Ducato/Relay/Boxer, but a bit of an eye-opener, anyway:
"40 Fiat-Chrysler worked closely with ZF-TRW in investigating the airbag
nondeployment in these 11 crashes. It conducted tests to identify what conditions
would cause airbag control unit electrical overstress. In June 2015, Fiat-Chrysler
received results showing that it took less than 100 microseconds for electrical
overstress to occur. ZF-TRW’s testing showed that a “microcontroller reset
occur[ed] at the same instant a negative transient creates an [electrical overstress]
event.”
41. By December 2015, Fiat-Chrysler determined that based on ZF-TRW’s
testing, airbag systems using a ZF-TRW airbag control unit could experience
electrical overstress at negative voltage transients of only -1.2 volts, while airbag
systems in vehicles outside the subject population could withstand negative voltage
transients up to ten times as powerful – approximately -14 volts.
42. Even after this detailed investigation with ZF-TRW’s cooperation, Fiat-
Chrysler failed to issue a recall until September 2016"
(From the document linked from this page: https://www.classlawgroup.com/consumer-protection/auto/trw-airbag-control-unit-lawsuit )
I've got a dead airbag ECU I can send to you if you're curious.
Quite possibly. I can't remember the exact details but largely it depends on what "domain" the system is classed as. Power train, safety, infotainment etc., as to how it's allowed to behave. Non critical stuff I think can shut down permanently (e.g. a fuse blows), other safety critical stuff must keep operating during adverse conditions.I wonder if the symptoms I described of the Renault's is part of this protection system??
Shutting the system down so it can't get damaged
