cheb
- Outer Hebrides
Mine is from Toolstation or Screwfix.On the subject of ducting then I'm a big fan of the Falcon brand of plastic trunking.
I would have thought a tapered washer/collar was required to open up the mandrel.
as there was some wrangling about their height
Usually but surprisingly the cap head worked as the countersunk Philips wouldn't take enough torque.I would have thought a tapered washer/collar was required to open up the mandrel.
That's what friends are for...I've started the scratio. The blocks are at least third hand and were last used to support an oil tank. The quarry mix is new but left over from a job and will be used to fill in the worst of the gaps once it's all settled I'll pour a really runny grout over the lot to stiffen it a bit. If I'm lucky I'll blag the washout of a ready mix truck and won't have to use whatever cement I have in the shed.
I like the little snap on box. Very nice colour trimsMade some holes in some 20mm plate to test out this 22mm U drill. It's awesome. Absolutely flies through it, gonna be great for making end plates rapid on cnc.
Assembled 90% of my new gaming pc, rest of the stuff to go in is currently in old (drives etc) and just need to install windows on it.
Ryzen 5 5600x, rx 6600 mech 2x 8g and 16gb 3200mhz vengeance LPX on a b550-a pro mobo with a wd_blue sn570 500gb m2 ssd in a forge 100r case for those interested.
Its an ancient and beat up 40", cheapest on FB, but still looks and works wellI like the little snap on box. Very nice colour trims
I like it!
Who needs a girlfriend when I've got a new pc and endless projects in the garageHave you got a girlfriend, like a real one?
