The_Yellow_Ardvark
I'm a citizen of Legoland travellin' incommunicado
- Going Away.
Insomnia is a real pain in the a...........
Should of used sanding sealer.
Oh well.
Who pegged you?TYA has pegged it![]()
the injector also had to be soaked in a hellish mixture of acetone and DMSO and supplied with 12 volts, simulating opening pulses, quickly touching the wire to the battery terminal. instead of two stunted streams, after the execution, the injector began to produce two streams of tiny drops. Not ideal, but the engine started smoothly and confidently. Now I won't lose money when selling.With virtually no tools, I was able to revive the fuel pump of a maxi scooter that had been sitting in the garage since 2019. I was able to soak up the tarred, sticky gasoline residue using acetone and DMSO + external battery power. The original fine filter has decomposed. We managed to find a filter from a car with a similar mounting method. The tank has been washed, fortunately it is made of HDPE. Tomorrow I'll try to start the scooter. Perhaps the injector will also require cleaning and power (boiling in DMSO in a water bath)
i saw that video pop up a few times too, great idea!I’m continuing my adventures in Pullmaxing. This time a trying out a technique I’ve seen on IG using body filling to make a plug to scribe around. Very effective.
