Using up an ‘air receiver’ plus some spare material and castors to make something useful that will create SPACE in my welding area.
What is it?Using up an ‘air receiver’ plus some spare material and castors to make something useful that will create SPACE in my welding area.![]()
I need to re-tool it now. Plain tooling doesn't really work for folding boxes, and I want a bit more flexibility. One of those sides was cut out for relief, and the other side was folded in the bench vice
You’ll have to tell me what it is. Best I can come up with is a portable air supply
What is it?
secondary air tank to boost air capacity ? only geussing mind
Today I started on a 1/3rd size spacer to add to the Flymo,
pictures when finished , as I havent a clue what you just said (nothing unusual there eh)
Today I made my workshop tidier than it has been in years.
Oh Rowlocks.
Cast top for the bird bath, I think it is no longer water tight.
The crack was old, very little was holding it.
3 metal pins across the crack. But not glued or fixed yet.
The crack was opened up, to give a decent bead for the glue stage.
The clamps, here are holding the 2 halves in line, so I can open the crack and clean up the stone.
Pitch pine strips, again across the crack. But out of line of the steel 6mm bars.
1 side is fixed with the screws going vertical. The other side the holes and fixings were drilled at a 10Deg angle.
So when you screw them up, it pulls the joint even tighter.
Glued up.
The metal pins.
2 pack glue.
The wood parts.
Can't believe it is not nails.
The crack.
2 pack stone resin glue.
A word to the wise, it will get hot.
The clamps are not holding it compressed.
But to make it easier to move round to glue.
The 4 screws, at the angle pulled the too halves up very tight.
Sealed with exterior grade stone sealer.
Back in place. Ready for water.
Total cost?
£0:00p
