angellonewolf
- bristol england
^^^^^would the arms be the problem if there more extended on one side rather than the other it would tip the wood enought for it to be out of square
They are ok but have little accuracy for a true cut, i have looked at a few over the years but the portable ones all suffer the same problems.
You are relying on pushing the sheet across the bearings for the horizontal cut and no sheet has perfectly smooth sides(excluding a edge banding panel).
For the vertical cut you are relying on the plastic wheels following the tube, they need some play to work.
https://www.axminster.co.uk/safety-speed-c4-panel-saw-110067
The Axminster one has issues with the spacing to the bearings so you get movements as the sheet progresses, to the point you can even see the sheet move on the horizontal cut in the promotional video on the product web page.
https://www.verticalpanelsaw.co.uk/zapkut-range/zapkut-zk/#
This offering the Zapkut has similar issues i looked at one at Woodmex a while back but just couldn't see the chance of an accurate cut either, its nice and portable for a odd site job, but its not a space saving replacement for a good table saw.
For them to work well the material needs to stay put and the saw to smoothly move around on accurate runners and bearings.
Its actually a neat design, would you consider selling it ?
bloody hell, how to over engineer a solution to a non existent problem!
plunge saw, rail and some trestles 1000s of joiners cant be wrong.
When the saw is in the frame does it pivot easily so you can alter the depth of cut?
With most ply you will get a better cut if you can first score/cut the first veneer layer then run through again at you full cutting depth.
I don't know what your problem is here, I'm just having a bit of fun with some random kit off eBay that was so cheap it was almost free.
Yup.bloody hell, how to over engineer a solution to a non existent problem!
No problem with you having a bit of fun, just looked like a horrendously complex thing
Ehh.Trestles aren't fool proof either.
While cutting 6 x 4 ply for garage doors, got about 300mm in and cut got harder, yep I'd gone half way through trestle with circular saw. THEN did exactly same at the other end on the other trestle
