frank horton
V twins are great but 4"s rule.........
- Crete, Greece
storey so far..
bought my house with the promise from the lecy board giving an approx cost to up-grade the house / barn to 440v at around €1200.......
they now want €15,000.....the pole with 3 phase on it is 14m from the meter.....!!!!!!!!
so onward .....we have decided to get a 7.5KV solar system later this year but without batteries for the mo.....
proposed day time use is from solar power, night time use from the mains using the special change over switch required....
Then within a few years to upgrade the PV to around 10KV and add the necc bateries to go totally off grid....
I've had a quote for an inverter box to get 3 phase from the solar system starting around £8,000....ouch.....but they are iffy about the size of the motors........
I have 8x3 phase machines, none with over 3HP motors.....
The question......
I hate electronics, so is it better to use/build a rotary converter or the electronic inverter type.....I want one inverter to supply the whole shop NOT 1 for each machine....
I need 3phase as some of the machines need reverse direction.....mills n lathes.....
simple is best and living in the wilds there nobody to install the inverter or fix it if it when it all goes wrong....
Normally wouldn't think of a PV system but our electric has gone from just 150euros for 2 months to almost 800 for the same useage....
our house is up a private road 1/2klm from the nearest house, so nobody is nicking electric....
be glad of some ideas please.......I have only limited knowledge of this kinda thing....Ta
The question......
