Unless you must box it up ie the welder needs to sit on it and free up some space I would suggest you make it into a tidy open Chassis job. It's gonna be more efficient all round if you do.Had the cooler running all day today with no problems at all, I was only welding up to 145 Amps but i did run a big pad of beads and it coped fine. Its open air atm so i may have to add another fan when i do the case.
I had exactly the same issue. Amazing feeling torch without the switch but with it it was a handful. I turned the speedbump down in the lathe and it made such a difference to when I was using it switched. I use a switch a lot more than a pedal so it was an essential move for me to go back to a round handle.I'd like to get it under the welder out the way eventually. Im not to comfortable with the speedway yet. With the speedbump handle and the snap on switch its quite a bulky odd shape to get used to, ive only just started welding again though, not done any over winter so im sure that hasnt helped. The torch feels a lot nicer without the switch on so i may just leave it off and just use the pedal.
Now its getting warmer i'll be doing a lot more practice in the garage.
No body is overthinking anything.It seems everyone is over thinking things,
I used to do loads of industrial ally AC TIG work when I was younger, we used to run the feed pipe right from the mains tap through the torch with the exit pipe plumbed into a drain, we were using big 400amp Murex TIG torches that would be like a donkeys dick to hold - maybe this approach could be used rather than some other heath robinson job?
Calm down, nobody's died jeezus,No body is overthinking anything.
1) recirculating from a closed system is far better than pouring good clean water down the drain unnecessarily. That's just a bloody waste especially when there are kids through out the world drinking from puddles.
2) its a well known fact tap water corrodes copper and will over time reck your torch.
3) tap water has conductive properties that can cause corrosion and HF leaking
4) portability
Building a proper cooler is not over thinking things it's been smart.
It's replies like this that put people off the idea of building there own projects to put into there own service.Calm down, nobody's died jeezus,
I'm only stating what we used to do in an industrial fabrication shop specialising in ally,
Most people rarely run high Amps in a domestic environment hence for intermittent use this would suffice rather than building something that looks ****
It's replies like this that puts people off contributing to threads
Any updates on this project mate.A total loss system is just bad all round if you ask me, plus we're on a water meter here so not an option at all.
It'll look a lot nicer when i get round to boxing it up. It works brilliantly, takes up very little space and if you're patient and watch ebay etc you can build one for under £100.
