sandeepkumar63
New Member
TIG welding
TIG welding is similer to gas welding but the main diffrence is the heat source. Like for gas welding you need to adjust the flame according to the material need (Iron, copper, brass etc.), but in TIG welding you need to take care a lot for diffrent material regarding welding parameters, polarity, shileding gas etc. You can use the same technique for TIG welding as you use in gas welding like hand movements, wire feeding. And if you are a good gas welder then I hope u can be best in TIG welding because it is a play of hand movement and controls. Go ahead
