DAPPH
as dyslexik as I'm daft
Furnace as in patio heater or more like a forge? I have a couple of 19kg bottles up in Yorkshire that I need to find a use for so looking for ideas, I don't need a piggy BBQ or a Minion patio heater before anyone proffers.
Make a Mini cement mixer with it or cut most of the body off and replace it with a bolt on frame of 10 mm stainless 2 mm thick wire mesh and use it cement mixer style as a powered garden sieve or compost sieve . Use the brass valve end as the boss to fit it on the driving shaft , it could be an external fitted simple sleeve & R clip . So you can interchange between mixer & riddle .
The micro mini mix can also be used with a small shovel of sand & gravel & a cuple of pints of tap water to clean a bucket of freshly collected salt water mussels of beards & barnacles .
