Farside
Badly Welded Man
- Ireland
You may see the majestic herds of wildebeest thundering across the plains...As you may have seen from another thread, we are currently travelling around the North of Scotland.
Very handy!cheap chinese scales, fed up with trying to balance on normal scales clutching a parcel and trying to see the display! seem accurate and £40 delivered
It is busy, not mental busy, from what I've heard late August is slightly quieterYou may see the majestic herds of wildebeest thundering across the plains...
I don't now! You ever tried to weigh a big parcel on bathroom style scales you can't see the display!I have to ask; Why do you need to hold the parcel whilst you're weighing it?
Only the urge not to spend money until I get the light bulb moment!Though it might be a weird quirk or some such you have.![]()
I do that with parcels that are too big to fit on the scales....I have to ask; Why do you need to hold the parcel whilst you're weighing it?
Very niceHad my eye on one of these (or similar) for a while...
PALSTAR AT1500DT 1500 Watt Differential Antenna Tuner
PALSTAR AT1500DT 1500 Watt Differential Antenna Tuner Palstar Quality, Innovative Design The AT1500DT 1500 Watt differential antenna tuner is the next level up in power handling from our popular AT1KP 1200 watt differential antenna tuner. It is built with the same quality and care found on...www.radioworld.co.uk
I'm not likely to need or want a bigger amp than the one I've got, so a nominally-rated 1500W tuner will do nicely and should be well under-stressed.
Manhood, it's good stuff went through a few branding changes before going.stamped palm tree
