Let us know how good the snow is , where in the french alps you heading I'm of to Val T 2nd of march havn't been on the planks since pre covid .After 15 years,some new ratchet straps for my snowboard boots. Just in time as we’re driving to the French alps later this week.View attachment 436667
Today I did not aquire, due to the theiving lying gits at RM. No attempt made and no card through door. Unless ofcourse they went to the wrong house again which seems to be getting extremely common!
rm never leave a card any more cant remeber when i seen one last only reason i got it as i was passing the post office and poped it twice in 1 monthToday I did not aquire, due to the theiving lying gits at RM. No attempt made and no card through door. Unless ofcourse they went to the wrong house again which seems to be getting extremely common!
Yeah they were just for scale my old 81s from back when i was on BTThe yellow handled pliers look like GPO/BT ones, always known as 81’s, proper name, pliers wiring no2
You've got a problem.Another Record Vice![]()
It should turn up in post next week. Then it will get stripped, blasted and repainted in Roundel Blue.
280mm diameter will make a whopping great fly cutter!I got some metal discs from Rapidmetals. It was the first time I used them and it took a week for the three discs to arrive.
I have previously purchased metal from M Machine but they did not have 280mm diameter steel.
180mm x 30mm EN8
210mm x 30mm EN3
280mm x 30mm EN3
I plan to use the 280mm disc as a big fly cutter
Unfortunately, the 280mm disc arrived a little damaged. Not too happy about that as I will lose approximately 3 -4 mm of the disc's thickness if I want a flat surface over the whole diameter.
I am thinking I should mig weld it it up before I face it.
The 180mm diameter plate will serve as an intermediate plate between a lathe backplate and an ER40 collet chuck.
It was worth adding a little bit of steel to get free delivery so I added the 210mm plate. It can serve as a backup if I mess the 180mm plate up![]()
Define "enough", so we don't go overboard.Yup. He's not got enough vices yet. Amateur.![]()
