Brad93
- Essex, United Kingdom
Every inch or two on the ones i've usedDo the plain rods have little tiny vee notches on the edge on one end?
I couldn't see any notches anywhere on them.Do the plain rods have little tiny vee notches on the edge on one end?
There were 2 square' ish bits that could be usefull for tools.Ah OK. When you have stellite cutting tools they put a little ground notch in one edge. That edge is 'top' giving the strongest orientation for your lathe tool.
Great cheers for that , yeah i bet if it imploded would be a bugger to get into shape !Don't forget to put a tightly fitting, thick plywood disc half way down. Put a largish hole in the middle.
I didn't and had to use a trolley jack inside the barrel to pop it back into shape.
I've the same tester, it's one Husqvarna supply (note the 9 digit part number beginning with 5) which considering a fair few of their machines use a 10mm plug it's daft it doesn't come with an adapter!Lots today, some more items expected..
Compression tester as recommended on here from LSE. Looks good, although " suits all plug types" does not appear to include 10mm for small engines. I can make an adaptor.
Zoro is mostly gloves. The orange are too thick and loose fitting to be useful, yellow very warm, purple are thin and fully coated/waterproof.
Alu cut carbide burr. Looks more like an endmill to me, I expect it will end badly.
Baby 4 jaw centering Sanou K02-50 chuck. This was an amazon "used", reduced from £70 to £12. Its very smooth and seems well made, cant wait to try it but the shed is a mess, cant get to lathe.
M8 ISO clutched tapping collet
6 jaw adjustable socket/chuck
Amazon mini belt sander for angle grinder attachement.
Where'd you acquire that from @8ob ?Today I acquired a topdon battery tester, seems a nice bit of kit, has its own printer. It’s bad battery time of year and my old prong tester has fell to bits, time for new.
Bob
I’ve got those Vessel screw drivers. Top notch Japanese tools that fit JIS screws perfectly.
I say old chap thats on the posher end of the scale..Today I acquired a topdon battery tester, seems a nice bit of kit, has its own printer. It’s bad battery time of year and my old prong tester has fell to bits, time for new.
Bob
