indy4x
- Pontypool, South Wales. UK
Discovery 2 manual uses MTF94 not ATF.
You are correct, my bad, its the D1 uses ATF although lots of peeps use ATF in the D2 as its cheaper and just change it more often. From memory I had an issue with my manual D2, you can buy MTF94 from the likes of CarPlan etc, I used some of this and it didn't make things better so went for LR MTF94 instead and while it didn't fully cure the issue it did make it less worse
