Electrode negative is swapping the polarity over. So putting your stinger in the negative dins socket and your work return in the positive. This puts current into work piece rather than the electrode and the result is lower penetration which can only help you out.Hi thanks for reply
But what does electro negative mean and 6013 ?
30 years since I have stick welded a little bit rusty to say the least
Try 1.6mm rods. You could try welding it in short bursts, like 10mm then let it cool, then another 10mm, etc..
horrible things small rodsTry 1.6mm rods. You could try welding it in short bursts, like 10mm then let it cool, then another 10mm, etc..
If I had to weld that with stick I would use a 2.5 electrode, with anything smaller the amount of flux / slag ratio to the electrode core is far greater and gets in the way, makes the pool difficult to see and control and causes the slag inclusions, run them at about 70 amps and keep the very arc tight, even drag the electrode along the joint, if possible set the joint up so that you are welding downhill a bit, not too much though about 10 deg is enough, its perfectly doable with a bit of practice.
When I used to teach welding a looong time ago before mig and tig was as common in fab shops as it is now, one of the exercises was a 4" long closed butt in 1.5mm sheet, most managed it without too much drama,
There is another method useful in controlling burn though used to be called broken arc technique, similar to the so called thin metal method used with mig, a series of overlapping tacks, you strike then break the arc, then while its still glowing red hot strike again, its important though to make sure the restrike happens before the slag cools or it will become trapped as a slag inclusion.
This was what i was trying to describe in my post -There is another method useful in controlling burn though used to be called broken arc technique, similar to the so called thin metal method used with mig, a series of overlapping tacks, you strike then break the arc, then while its still glowing red hot strike again, its important though to make sure the restrike happens before the slag cools or it will become trapped as a slag inclusion.
But i couldnt think of a good way of describing it and didnt know it had a name.Try 1.6mm rods. You could try welding it in short bursts, like 10mm then let it cool, then another 10mm, etc..
I have a rural upbringing, agricultural background and have had to help with make do and mend repairs in poorly equipped farm workshops, so im quite used to random acts of desperation to get things fixed with limited options.
Doesn't look galvanised, looks like zinc and clear passivate which is totally different, and easily weldable.
Lack of experience and 2mm rods is your problem, you need to be running 2.5's with a machine that has a decent amount of arc force.
That's the ticket .
Also , not being funny , can you see what your doing ?
Hi thanks for reply
Call it bobbing in the broken arc technique never heard that or forgot it along the wayIf I had to weld that with stick I would use a 2.5 electrode, with anything smaller the amount of flux / slag ratio to the electrode core is far greater and gets in the way, makes the pool difficult to see and control and causes the slag inclusions, run them at about 70 amps and keep the very arc tight, even drag the electrode along the joint, if possible set the joint up so that you are welding downhill a bit, not too much though about 10 deg is enough, its perfectly doable with a bit of practice.
