ronan
My vfd is wired to my bridgeport head and that was fine, the motor runs ok, but of course me being me i forgot on a bridgeport the motor needs to run in both directions, depending on which speed range you are using.
I thought it was a simple matter of running another wire from the control wire area on the vfd to the switch and bobs your uncle.
Tried that and nothing happened, the motor ran in one direction as it always had, but would not run in the other.
The switch is a three position NO one that is original to the machine (Tom Senior). In the middle position it is off and if you turn it left or right it should run the motor in forward or reverse.
I have included pictures of the manual, if anyone can tell me what to do it would be a great help.
