We have installed stables in the end of one of our barns. Most of the time it is fine but with heavy rainfall like recently, the water comes up through the joins in the slab. We are on a hillside and the ground behind the shed is higher (rapidly slopes up about 10ft from the rear of the shed to a flat field. So it appears that as water soaks into the ground, the pressure is forcing it up through the floor of the shed. Is there anything that is not massively drastic that could be done to stop this? The only solution I can really think of is to remove the stables, lay a membrane on the exisiting floor and then pour a thick slab on top of that in one piece but financially it doesnt make sense to alleviate the effect of a few days a year of wet, so I dont think thats going to happen.
The only other thought I had was whether it would make sense to deliberately make holes in the centre passageway that could be covered with a grill to actively let the water out where we allow it rather than inside the stables themselves the shed is 34' wide by 40' deep with stables all around the edges so dont know if drainage holes to let water UP in the centre passageway would alleviate the pressure pushing it up through the slab at the perimeter?
