ive used 2 bent welding rods and found gas pipes water pipes leccy cables and drain pipe . it works well for mostAfter having a good scrape around I reckon we have a spring as the patch of ground is always very soggy, any one ever done any divining?
It's quite a big area that gets soggy so I'd like to narrow it down if I can,ive used 2 bent welding rods and found gas pipes water pipes leccy cables and drain pipe . it works well for mostif you know its a soggy patch already dig it up and take a look . did one for a customer . her lawn was rising in a hump in the middle
dug it up- and the crappy builders had dumped a load of wood of cuts under the turf and it had all swelled up
It doesn’t for me, I worked with a man that was mustard at it, I tried many times & got nothing.It works for me too, fencing wire bent over and grip loosely.
It's a long way from any water pipes, we've all got springs around here, we have one by the houseWith no water usage at your property have you tried sounding the valve in the street serving your supply to see if you can detect noise which could point to a leak on your pipework?
I think your pack of fuzz balls can find any & all mud/water.....seem to be expert at it so far.....After having a good scrape around I reckon we have a spring as the patch of ground is always very soggy, any one ever done any divining?
No drains we know of, the diggers a cracker and the lad is spot on with itYes works for me too, I know where some of my water pipes are so have used rods over-them to prove it works.
Blocked drain perhaps? Ive a few of those I need to dig up.
Are you sure the digger is big enough?
Where's the outlet , because you absolutely need one...No drains we know of, the diggers a cracker and the lad is spot on with it![]()
One local home improvement radio show host's favorite line was:Used to have quite a lot to do with drainage work.
Water really wants to get back to the sea, and it really gets irritated if it can't.
from the ground work shown I would agree with that , bang tidy workNo drains we know of, the diggers a cracker and the lad is spot on with it![]()
