Blobber
- lincolnshire
Its a long way from anything, sceptical tank, drains, water pipesAre youon main drains, or septic…its not a soak away area is it
This could go on forever, I'm happy for you all and the fact you can't explain it does it for me, magic rods that find water, water pipes, drain pipes electric cables, cable joints, leprechauns yes it's all unexplainable.....If only you were with me the day I found a blocked drain in the middle of a field, I mean, its not luck, nothing else can explain it, dont let it bother you though if you dont have the gift.![]()
Make sure you set them.to automatic so they pick up everythingTomorrow I shall go divining![]()
reel you inMake sure you set them.to automatic so they pick up everything
Dont hold them too tight, and walk slow.Tomorrow I shall go divining![]()
Bit concerned they may not work properly if the ground is saturated with water. Pipes are either conducting metal or have water in them and cables conduct, therefore they stand out from drier surroundingsHere we go, I've gone for 18 inches as that seems a nice length
Do I need to wear sandles or any other hippy new age stuff
Ley lines, invented by Alfred Watkins in the 1920's by joining up things from different archeological periodsI use a couple of bits cut from wire coat hangers. Bent at right angles and the short ends passed through plastic pen barrels.
Honey bees like local ley-lines.
In Britain it is almost impossible NOT to find water. Especially in Wales!I think your pack of fuzz balls can find any & all mud/water.....seem to be expert at it so far.....![]()
fixed it for ya......Oh ye of little faith .
Trust theforce !"Swartz"
