davegeezzer
brightspark;. i put a new belt on for them and asked do u drain it often .drain what was the answer :(it had a 5 gallon reciever and i drained 4 gallon of water from it :laughing::laughing::laughing:is that takin the p said:Blimey that makes mine look like nothing !!! Ive got tomorrow off so ill get it running and keep draining it down,
I was going to run the pipe work in copper pipe would 15mm be ok or should i use 22mm ? and is it ok to solder the joints or should i use compression fittings?
