foy9999
- East Kilbride
bit of a weird one here...
I do slate-roof repairs and have been called to one property many times in recent years for leaks here there and everywhere.
Got an emergency request from them this week as water coming in via the fan in the bathroom
Went today and checked all the slates above the bathroom. It all looked fine.
Next thing was to inspect from inside the attic
Again. all good. No sign of daylight through sarking or water tracking along the woodwork.
I then found that the pipe (to vent on roof) above the fan was wet but only at the bottom. About 8" up from ceiling there was a joint (2 sections of pipe) taped-up with what looked like insulation tape.
The tap was wet and not really holding anything so I removed it and wrapped the joint with Denso tape.
Question is - where would the water be coming from?
There is a hood on the pipe outside and the rubber apron round it is tight and lead flashing was bone-dry under tiles.
The only thing I can come up with is condensation from bathroom was running back down the pipe and out of the taped joint
Seems unlikely but what was it Sherlock Holmes said......
slates, hood, rubber apron and lead flashing all good around vent-pipe
vent-pipe was 2 sections joined with tape and bottom section was wet
pipes now joined with Denso tape but where was water coming from?
