Paul.
Moderator
- Northampton. UK
1.6 box section arc welded, you probably couldn't have chosen a much more difficult job for a beginner. your welder may have a low ocv as previously said, this will make it very difficult to strike and maintain an arc at low amps. try warming up the electrode by striking and running a short bead on a piece of scrap (something heavy enough not to burn through), then move straight onto the job, the arc will then strike much easier,
if you stick, a twisting movement will usually free the electrode although thin ones are more difficult and will bend.
You can also recover damaged ends with that piece of scrap plate, up the amps a bit then stroke them on the plate and force an arc, it will be very unstable until its burnt back to sound flux, then shorten up the arc for a couple of seconds and stop.
To be honest something safety critical such as a car chassis should really be mig or tig welded by an experienced welder.
