I am having the same problem and came across this post.
I can't see how it is possible to drag a rod into a corner and back out again, keeping the angles correct.
Can anyone point me to a video on YouTube showing the correct technique?
Why ?Don't ever start in a corner as has been said, always try to run into then out of the corner, standard practice to avoid crater in the corner of the joint
Why ?
As you weld toward and into where you previously started ie corner you burn out any bad bits as you link up. pause for a second and that takes care of the crater as you stop
You don’t start in a corner when your stick welding because the second you start your rod your creating slag and spatter and your rod is cold and the steel is probably cold and there’s a chance of arc blow that’s a pure recipey for a mess. When welding with stick your rod is warming up that first second when u long arc and away you go with a 6013, you don’t want to be doing
Works ok north of scotch cornerYou don’t start in a corner when your stick welding because the second you start your rod your creating slag and spatter and your rod is cold and the steel is probably cold and there’s a chance of arc blow that’s a pure recipey for a mess. When welding with stick your rod is warming up that first second when u long arc and away you go with a 6013, you don’t want to be doing that In a corner.
