The temperature of a molten metal can be higher than the melting point, like water can be at a higher temperature than ice until it boils.
According to Wikipedia the surface temp of the sun is 5500 degK
I meant at night
I think water can get hotter than 100 degrees, if its under pressure and contained, not intially sure though.
Yes, water boils at 100 degC at atmospheric pressure.
as does the volume of liquid change with different pressures.
If its critical they weigh it.
[stick in oar]
Actually, you can have liquid water at 100C and 1atm. You need to add extra energy to get it to boil. This is why, in those school experiments where you stick a beaker over a bunsen burner and put a themometer in it and do a graph of temperature over time, the graph goes flat for a bit. Then the water boils and the beaker explodes.
[remove oar]
