Gareth J
- North Cornwall
Hi all,
I recently picked this machine up and I think it's going to be alright but I'm not entirely sure what I've bought or how to work it!
It's physically pretty big and weighs a lot.
Single phase and attached to a huge, ancient bakalite and possibly original 3 pin plug (fits into standard socket) with a 16A bullet fuse in it. I've blown the fuse once and the thing is also trips the rcd pretty regularly. I've got some 13A sockets that were originally wired for 15A so I've been using them but it wont be a major issue to get a 16 or 30A round type plug/socket set up.
The sticker on the back seems to call it a 200Mono
I'm used to a Clarke 150 so the number of knobs and dials on this machine are a bit confusing:
1: No idea, 4 settings, pictures include arrows pointing up/down
2: Voltage output indicator?
3: Amps output?
4: Again, no idea. more arrows
5: picture suggests distance between torch and metal. 0-10 on the dial, 0 has argon written next to it, 10 CO2. Not sure exactly why the distance between torch and type of gas used is related but I'm currently on Co2 so stuck it towards the higher end.
6: wirespeed. managed to sus that one out.
Came with a fair bit of 0.6mm wire left. would prefer 0.8 but I'll use this up for now.
had a play on setting #2. seemed about right for the 2-3mm steel I was welding. much higher and the RCD starts flipping out. setting #2 seems similar to getting on for max output to the clarke 150. There are two earth wire sockets in the pic above^^ one with a "little earth" pic the other a larger earth pic... any ideas there?
So can anyone point me towards somewhere I can find a manual for this or a similar welder? I've tried a bit of googling but no come up with anything. So I can learn about what all the knobs and dials do/tell me so that I can have a go at setting this up with some kind of logic...
Any thoughts, opinions, suggestions welcome really!
3: Amps output?
