- Birmingham
I agree 63A would be overkill, go with 32A as long as you have 32A max mcb (and wiring to suit) feeding it.
... even on the lowest setting, I'm going to struggle on bodywork. I think that's why the garage I bought it from was selling.
Something I noticed in use; the voltage gauge hangs after you have stopped welding and there is a small spark/arc if you touch the tip to the work. After the spark the voltage dips back down. Normal? Problem?
Anything I should do in terms of servicing this beast?
The circuit board issues; any preventative maintenance I can do? Not sure when it was made, but its certainly not new and looks to have seen some work...
Migatronics usually have very low minimum current settings. Mine (180 MXE) goes down to 20 amps. Worth checking before you assume it won't do this.
There is a circuit diagram for the early 180 which is based on discrete components. Sent to me by a member, and I've cleaned it up a bit to make it more legible. Should tell you most of what your PCB comprises - even the later, i.c.-based types share a logic in the way they are designed.
From your serial number 80140125 I think the date of the machine is 14 Jan 1980 - I'm not sure whether it was machine no. 25 made that day?
Best regards, T.
Even if you find the parts you are going to have some fun getting it back together AND working! Another member on forum done same and then he had the fun of trying to find a replacement (££'s)PS. If anyone's thinking of dismantling a 12 position rotary switch 'cos "it's a bit stiff", think very, very hard. About a billion, microscopic, spring loaded components are waiting to propell themselves into forgotten corners of your workshop
