hi all i have just inherated a old atlas copco compressor and was just after some info on it, ie cfm hp just so i can get a idea of what tools and guns i will be able to run.there is a plate on the side but it dosent really make any sense to me.on the plate there is a few details here goes
1. ser nr, B170237
2. type, LC302
3. capacity 150ltr -5.3ft3
4. work press kg/cm2 10.5 - lb/in2 150
5. test press kg/cm2 15.8 - lb/in2 225
6. work temp 100c 212f
7. manufact 1967
i think no1 is the serial no,no2 is the type,no 3 is the size of the tank no 4,and no 5 not to sure, no 6 is max working temp,no7 is year of manufacture
the main reason i had this is because it had a big tank and i hoped it would run a chisel,a gravity fed gun,tuoch up gun, a die sander, and a recipracating saw, not at the same time though induvidually. it is good working order i think and i think it could be a good bit of kit with a bit of tlc any help on this matter is gratefully welcome as im new to this thank you in advance
adam
1. ser nr, B170237
2. type, LC302
7. manufact 1967
adam
