brokenbiker
- Llanbobyll, south wales
I have 2 springs, both near identical apart from maybe a mm or 2 in length. I want to replace them with springs with a bit more force. I cant change the outer diameter as they fit in a hole, and I cant change the internal diameter as the top requires a locating pin to slide inside.
so, will using a longer spring made with the same csa spring steel give me more clout? or could I just pack the bottom of the hole out with something to give more compression?
