Won’t have any water mate I’ve got a proper blasting compressor with refrigeration unit on ityou need glass beads to get the even finish youre after, but probably cheaper to get a specialised blasting company to do it in a room by the time youve set all your gear up and got frustrated every time the water from the compressor clogs the bead in the pot![]()
i have a mobile and never have a problem with water .once the gear is set up get it running without introducing the media. after 5 minutes the air is getting warmer and comes through moist then just dry warm air as all the pipes and pot are warmed up. then start blasting and the gear will run all day without any problem . if the media is consistent it never needs re regulating or touchingah, that'll make a hell of a difference, i thought it would just be a standard road compressor.... those things are a nightmare for blasting with
Nah it’s got a refrigeration unit built inah, that'll make a hell of a difference, i thought it would just be a standard road compressor.... those things are a nightmare for blasting with
