Never seen one. Sounds like real kit though. I've used degreaser baths before but they don't offer a heated solution nor do they work with vapour the part is just soaked and dries offIt was good kit, no idea if such tanks are still available? Midway down inside of tank had a refrigerated coil all around, heater at bottom, which of course heated up a small amount acetone, which then gave off, vapour. Was cool to watch your job get lost in the mist. Maybe you have used or, seen similar?
I've not heard of that before. What's it like in comparison to acetone Jim.
Lays in bottom as a sludge, medium and sludge drained every so often, depending on use. I actually thought acetone was now banned?
I get that the photo may be the cause as the weld is clean & shiney in real life but the pic itself is saying not enough EP and/or shielding issuesheres an outside corner butt weld i actually did with a R-tech funny enough on 2mm 5052 plate with 4043 filler, 8lpm no lensm the beads are fairly mirror like finish, sorry for the crappy photo
The second/6010 stick mode got added with fan on demand some years back, unless they've 'facelifted' it again AC waveforms stayed in the set up menu along with preflow time and various other things that should really be changeable without turning it off and then on again while holding down the parameter buttonThe later v205 models have a button on the front panel for changing wave shape.some also have a 6010 stick setting not found on other variants
Is there much difference in arc noise/harshness between soft squarewave and the advanced?Like you once i found a setting that works i leave it there, on my dynasty i find that the 'soft squarewave' is the most universal so it stays there mostly, once again its in a hidden menu but luckily it can be changed while the machines running, used it on 'advanced' briefly last week when Langy came over as we needed a more penetrating arc,
not a great deal different but the 'soft' setting feels better for most stuff.
the second/6010 stick mode got added with fan on demand some years back, unless they've 'facelifted' it again AC waveforms stayed in the set up menu along with preflow time and various other things that should really be changeable without turning it off and then on again while holding down the parameter button
The elga multistage reg with flow meter I think is the same as mine badged Esab optiflow. They are very good but I have noticed as you say the scale on the flow meter is very course. Mine over reads by just under 1lpm when compared to my peashooter so I usually set it at the reg then adjust the flow till I'm happy with the results at the peashooter. Inside corner I can get away very well with 4lpm very well, butt joint and outside corner 5-6 usually (if I remember to adjust it.) to me the last run on the last pic does look a little compromised with contamination as some of the freeze frames look a little discoloured but as you say it could be a balance issue as apposed To gas or a bit of both maybe. Fwiw a good quick cheap modification to start with would be to replace the collect bodie set up with a lens and play with the balance till the reflection of the tungsten is gleaming in the pool. To be honest though the main problem was with the Si filler causing the dull grainy appearance and I don't think that's down to gas flow at all, more likely set up and or technique.These days the reg is newer but the same model and i ditched the Harris flowmeter for a GasIQ/Elga optimator to add a second stage and reduce the initial surge when striking an arc- noticable improvement to accuracy of arc striking/initial arc stability and saves a little argon too
Its most definitely the photo, sorry it was taken on a crappy phone at the time, and i agree how it looks!I get that the photo may be the cause as the weld is clean & shiney in real life but the pic itself is saying not enough EP and/or shielding issues
Personally i don't see any signs of proper shielding problems in the fillet welds Brad posted... the occasional dark fleck in the weld could be from various things but even a slight shielding issue produces more consistant signs of contamination. Typically a scummy weldpool that's subtly different from the sluggish/scummy pool you get when AC balance is biased too far into EN
Inaccurate flowmeter is a good point, unless i missed it we don't know whether 6lpm is at the regulator (with or without a thorpe tube flowmeter) or from a 'peashooter' on the ceramic. That said IIRC R-tech regulators (if it's even a rtech reg) are notorious for under reading by quite a chunk? Tube to tube joints aside a fillet weld is pretty forgiving when it comes to flow rates compared to an outside corner where higher flow rates are more likely to cause problems than lower; drawing in air from a venturi effect
it was just to illustrate that clean beads are possible with an R-tech. I've not heard of that before. What's it like in comparison to acetone Jim.
It's all I use for all my Tig now. The biggest plus is obviously the saving in gas the collet body's do a decent enough job but the gas is released through a number of holes round the outside its then swirled and deflected off the walls of the cup and forced down to shield the pool. The lens the gas goes straight down evenly passing through a fine mesh which disperses it very evenly over the pool like a blanket as such. The even and direct coverage makes it much more efficient thus allowing for lower flow rates.Its most definitely the photo, sorry it was taken on a crappy phone at the time, and i agree how it looks!
I've full EU and U.S qualifications in alu plate and tube TIGit was just to illustrate that clean beads are possible with an R-tech.
and yes, your right, the best place for an R-tech regulator is over your shoulder - its just a generic chinese item rebadged.
Richard, do you always use a gas lens on Aluminium? I find it unnecessary alot of the time.
made from a €1.50 copper reducer - then i machined a nylon insulator and threaded it and pressed it into the cup, 2 layers of scotchbrite - i can weld 2inches at a time of titanium with no trailing shield and no colour contamination. ive a number of these in many shapes and sizes
I saw that I think on an earlier thread. Looks just the business for those exotic metals. Yeah even for stainless as you say a lens set up is more crucial if surface oxides are to be kept to a minimum. Ti I've never had the pleasure of welding myself but understand the crucial fact of flooding it with gas to keep out the contamination oxides.heres one of my diy lens'smade from a €1.50 copper reducer - then i machined a nylon insulator and threaded it and pressed it into the cup, 2 layers of scotchbrite - i can weld 2inches at a time of titanium with no trailing shield and no colour contamination. ive a number of these in many shapes and sizes
