What sort of machine is it ? Piston ? Direct or belt drive ?
my comps ran for 35 years on motor oilits not that critical what type
What motor oil are you putting in? I have a 10W40 semi-synthetic oil for the car, will this do the job?
2 other probably stupid question:
1. Do we need to change the oil, I could not find the way to empty the sump ?
2. How much does a compressor take? I have not seen any gauge telling the oil level neither.![]()
Yes too much oil will cause churning and the oul will get hotter. Some have a site glass, others you cant get more than needed as the fill hole is at the level of the oil.Can we really put too much oil in it?
Cheers
Superfly
its preferable u have airfilter fitted to reduce wear due to ingress of dust ect .the only servicing needed is drain tank daily. in use clean air filter every few month depending on what use . once oil changed it will last years ,the only other thing is check tension of belts for wear and thats itI really need to check this properly and get the proper servicing.
How often are you changing the oil?
I have another question, I believe something is missing on my compressor.
I believe it is the air filter, I have use a arrow to show it on the below picture.
What to you think should I get a air filter on it?
I try to contact the main dealer but they are not answering the email
I will try to call them in on friday if I can't before that.
Thanks a lot for the help
fit whatever filter u can get hold of that will go on. mines of a stilh saw. any freeflow filter will do . even a tube will do with holes drilled along it and wraped with a scotch padDo you know if I can use any air filter from any compressor?
I don't know how much the previous owner use it like that but based on the dust on it I would say that the compressor was not on a free dust environment.
I can only hope it did not suffer to much.
At the moment, I am not using it I want to this fix before. I just drain all the air yesterday and refill it to see if it was in working order and it is.
